E000677 0080 on irc3220
  • iCornerstone
    • Aug 2009
    • 42
    Hi,
    I seem to get this error message:
    E000677 0080
    when i try to print anything from my PC on the IR c3220N
    Any help would be much appreciated
    thanks
  • teckat
    • 16083
    Error E677 0080- occurs when sending print jobs to any printer on the network that has an imagePASS C1 or C2 attached to it.
    Verify the copier and the imagePASS C1/C2 have the latest system software installed.
    2. Verify that all posted patches for the RIP (either the imagePASS C1 or C2) have been installed.
    3. Try re seating the Open Interface Board in the copier.
    4. Try re seating the interface cable.
    5. Try change from the PCL print driver to the PS print driver.
    **also check the cable between the ImagePass C1/C2 and the Reader unit
    if u have a C1 image Pass software should be v 2.1/ there is also a patch when using
    Microsoft PowerPoint
    also the iRC 3220 should have Firmware- v90.03
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Do you have a imagepass!!!!
      Is this the same machine that you posted in that other thread.
      • 5185
        • 13
        I had this error
        Think it's because I sent an avi movie file by mistake along with the jpg's I was printing.
