IRC3200
  • CrapAimer
    • 296
    IRC3200
    Hi folks
    Have a Canon IRC3200N with a error code, E00732-0001. Thinks it is a Fuser code. If it is how do you clear it down.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    E732 This is a communication error. The reader unit is not detected at startup. Check the cable that connects to the reader unit and machine towards in the back first. There many other reasons for a 732 but try this first.
    • montana
      • Aug 2008
      • 392
      E732
      0001 A fault is detected by the main controller PCB in the communication between
      reader controller PCB and the main controller PCB.
      Main cause The connector has poor connection. The reader controller PCB is faulty.
      Action
      1. Connector, Reader controller PCB
      Is the connection between the connector J1014 on the main controller PCB
      and the connector J409 on the reader controller PCB normal?
      NO: Correct the connection.
      YES: Replace the reader controller PCB.
      • CrapAimer
        • 296
        Connector was bashed in
        Many Thanks for all your Help
        George
