ir3300 e000677-5802
  • nick_schmidt
    • Jun 2009
    • 31
    ir3300 e000677-5802
    ive got this error code on my canon imagerunner 3300
    im thinking main board
    i have swapped the part from another machine and have the same problem....
    any thoughts????
    please help
    Its been a while since I worked on a 3300 so from the service manual -
    E677
    0001A fault occurs it the combination between any of the printer boards (acces-
    sories) and the main controller PCB.
    Main cause Any of the printer boards (accessories) is faulty. The main controller PCB is
    faulty.
    Action
    1. Connector
    Is the printer board (accessory) connected correctly?
    NO:Correct the connection.
    2. Printer board, Main controller PCB
    Try replacing the printer board. Is the problem corrected?
    YES:End.
    NO:Replace the main controller PCB.
    Have you tried swapping the ram?
    • costd
      • Jan 2008
      • 409
      Just a SWAG, but I would try reloading system software as E677 has several items to check, but the 5802 seems to be SSW related.
      As I said, a SWAG and your milage may vary
      • nick_schmidt
        • Jun 2009
        • 31
        thanks all!!!
        im going to try a few of your ideas and see
        what happens
        thanks very much
