iR 1600/2000 papaer jam from all trays
i have an iR1600 that all the cassette trays jammed at finisher, at fusing unit when i make many copies. i found that when i make even 1 copy, the paper will lift 2-3 papers. all tray do so. all trays are working abnormal. except for bypass. what is happening???
Jam code would help. However, if all trays are feeding multiple pages then that will have an effect on timing of the paper as it passes each sensor flag likely resulting in a delay jam. Replace/clean the pickup/seperation rollers in each feed assembly.No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.Comment
easy> double feed> replace p/u tires & sep. rollers**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
