C7000VP error code E000003-0102-05
  • jharris
    • Aug 2025
    Can anyone provide information for this error code. Call 800-258-0258, ask for John
  • hemai2005
    Professional Print
    • 108
    low temperature detection of
    external heat upper roller main
    thermistor
    When detecting temperature at
    standby/during print decreases by 80
    deg C or more against the target
    temperature for 1 sec or more.
    Check if the connector at external heat upper roller heater is
    disconnected/not securely inserted -> disconnect and then
    connect the connector
    sigpic
    Learned a lot will become an expert
    • jharris
      There are two fuser units, the main and the secondary for thick stock or duplex. Does it let you know which of the two is sensing low temp. - is that what main in "upper roller main" means. When first turned on, it comes up with this error code in about 30 seconds then in another half minute of so shuts off.
      • CanoNiR
        • 50
        Primary fixing
        1. Check if the connector at fixing heater is disconnected/not
        securely inserted -> disconnect and then connect the connector
        - heater harness relay connector inside the fixing assembly
        - connector at the fixing heater driver PCB (J4404)
        2. Check if the fixing heater harness is open-circuit -> replace
        the fixing heater
        3. Check soil of the fixing roller sub thermistor -> clean it
        4. Check the attachment of the fixing roller sub thermistor ->
        reattach it
        5. Check if the connector at the fixing roller sub thermistor is
        - connector at the fixing external driver PCB (J4192)
        - connector at the fixing duplexing feed driver PCB
        6. Replace the fixing heater
        7. Replace the fixing heater driver PCB
        8. Replace the fixing roller sub thermistor
        Experience is the best adviser!
        • teckat
          • 16083
          inspecting the engagement of External Heat Roller Assembly> must contact Upper Fixing Roller properly/ inspect to see if anything blocking
