How do i clone my HDD
Canon ir 6000i
hi man i dont recomend clone hdd just have sst and firmware and reformat the hdd.replace it when needed.if you need it give me you email.by the way what kind of ir 6000 you have cause there's alot of varietion of 5000 and 6000.there is no glory without sacrifice -
model no. ir6000i
thax for replying............
Its ir6000i with the controller version 5403.2442.2201............well i'm very new to this system and i hve been using for the last one and half year....its a great system and still date no major issues..............
Actually i wanted to clone the hard disk because if something happens to my hdd .... so i can replace it with the cloned one........ if i'm right .....if not suggest me........ My email id is Amitlama_78@yahoo.comComment
one more thing ...............my tray 2 which is a4 does not print well .its slightly misaligned but print quality is good...........is it the pick roller?Comment
Sir, My IR105 having e602 problem, and always hang but once i take the cable and clean the dust i put it back it become normal for sometime then problem come again. May i know how to use SST install to a HDD, pls tell me. Is it the same as we format PC by using the OS run it....?
You need the SST and the firmware for your copier the IR105. You also should have a read of a version of the SST manual which explains how to use it and which methods of connecting a PC to a copier work with yours.
When you get E602, you may be able to make it go away, but the error will come back as it did in your case.Comment
Now having...But machine running now....I think it will come back. duno when come back. So do you have any website to get this SST and IR105 Firmware?Comment
ravichandra
