Canon IR1600/2000 printer cover
  • tibbs
    • Aug 2008
    • 225
    Hello friends, i have a Canon Ir1600/2000 with a problem check printer cover. I have checked an recheck all doors and covers on this machine.I have also checked the switches on the doors but the same problem prevails. Can anyone shed some some light on this problem?
    Thanks much in advance.
  • reymiguel
    there is not only switch in the lower left side cover...a sensor hiden... actuator will actuate if it was hit by
    the said cover
    • hemai2005
      Professional Print
      • 108
      that is one door down left you can check for it ,some time open but appear is closed
      this the first, if not solved post again
      thanks
      sigpic
      Learned a lot will become an expert
      • tibbs
        • Aug 2008
        • 225
        Canon IR1600/2000
        I have checked these doors but i get the same problem and also the switches.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          I had a case like this.
          Was there a jam? What led to the reason for opening the cover or doors in the first place.
          There are times when a machine jams and the customer opens up doors or covers and pulls paper out,
          the sensors don't reset, especially the one's that are located on the pick up assy's.
          disconnect the pick up's, either one or two from the dc controller and restart the machine with all
          the covers close and see if the message is still there. If not then you have found your problem. You can reconnect the pick up's
          back onto the dc and see if it comes back. In my case the machine was good after that.
          Check it out.
