Fixing Error= / were u working on unit before error ?/ did u have a paper jam in it/
+ check actuator for the fixing inlet sensor/ can break or become sluggish and cause an error code E001
actuator (FC5-5145-000) and the return spring (FU5-2175-000).
yes i have a paper jam and clear it, i also have check and clean thermistor, shutter thermistor it's ok.
i will check actuator sensor and return spring thank's for this teckat
How about clearing the code E001 in service mode. Did you get to do this yet.
E001-xxxx Must be cleared by service mode. Copier>function>clear>err>ok then reboot.
yes after clearing error code i get the same code after machine ready for about 2 minute
