can you please explain what do you mean by ; Replacing th DC controller.
thank you.
It means you should call a tech to come out and look at your machine.
Notatechie - "I am trying, but I don't know how to go into Service Mode. If I just go in and press *then 2, than 8, then * it does not do anything."
SCREWTAPE - "Try harder.."
Follow this, But once in service mode DO NOT DO ANYTHING ELSE (Or you could make your machine in-op)
Press the yellow reset a couple of times...
Press {*), 2+8 (Together), {*)
Tap Copier, Then Option, Then User
Under there you will see "SLEEP", Tap it
Press the "0", then OK (on the display)
Then press reset until your back to the normal screen
BUT this may not fix the problem, there may be an underling issue apart from this
you helped me getting my canon up and running again last time, by folwing the sleep steps, thank you, but today it is giving me the same error code, any advice please
Best advice is to place a service call to who supllied you with your deivce
Sounds like it's a main controller issue you have
If it keep flagging up errors it best to get someone in to look at it instead of asking for help on here
We can only advise, but without looking at the device 1 on 1 we can only help so far
