Canon IR1025if Black Display
  • Tim C
    • 167
    I have a Canon IR1025iF giving me only a black display. It goes thru its rotation power light is on...seems dead, other than that.. Any and all help will be appreciated. I have a 1023 manual, the same machine i think
  • mrfixit51
    Lead Service Technician
    • 1975
    Similar, not the same. If you put a doc on the glass and press copy,, do you get anything out of it?
    • Tim C
      • 167
      No Nothing...at all happens,, I am thinking dc controller or Power Supply
      • mrfixit51
        • 1975
        Hip shot would be power supply,,, forgot to ask,, was green idiot light on, on the front panel?
        • Tim C
          • 167
          Yes the Green light is on.. I flip the power switch on and the machine cycles, screen turns black. nothing works after that. light stays green
          Tim
          • Windpomp
            • Nov 2008
            • 9
            Were u busy doing a firmware upgrade when it happened?
            • Tim C
              • 167
              No, the customer was running copies and turned it off to let it cool down "they said"... and when they went to turn it back on , black screen came up, green light, rotation and thats it.
              • Windpomp
                • Nov 2008
                • 9
                Last time i had a problem like that it was the main board, teck was busy with upgrade and switched the machine off too soon. We had to replace the DC cont(main board). Sorry.
