Canon NP6221 Black Copies
  • jamesw_80465
    I have a Canon NP6221 that is putting out black copies (Dark background but the image is still visible). I have checked the main charge wire and it appears to be good. Any help would be appreciated.
  • Herrmann
    • Jan 2006
    • 792
    Ok, lets do it from the scratch:
    Did you clean all mirrors, including mirror nr6 ?
    does the scanner lamp fire up correctly?
    are the spacer rollers of the development unit worn?
    make sure, that there is genuine Canon Toner used!
    Hope, this helps
    Greetings from Germany
    Herrmann
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • jamesw_80465
      Thank you for your information. I found out that there is a density slider inside the front cover and someone had run it all the way to dark.
