Downloader PCB
  • kuby
    • Oct 2007
    • 1408
    Downloader PCB
    Is there somewhere I can get or borrow a downloader PCB FY9-2034-000 ?
  • SCREWTAPE
    East Coast Imaging
    • 3396
    You can get from canon. Or a authorized canon dealer. I'm guessing your not authorized?
    • kuby
      • Oct 2007
      • 1408
      No, I went out on my own about 5 years ago after the owner sold it out from under me after many years of service. The new owners did their best to piss everyone (including customers off). Could not stand it anymore, they had never been in the copier business and did not know the first thing about it. They are struggling now.
      • teckat
        • 16083
        do u know any techs who work for a Canon Dealer, I'm sorry but I am out of town now and will not have access to lend it to you
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Its rough man just hang in there.
          But that downloader tool will help you with that skewing issue on that finisher.
          • kuby
            • Oct 2007
            • 1408
            Found one - ordered it today...with as many of these that I am selling to banks as such I figure I might as well have one.
            • teckat
              • 16083
              good luck !!!!!, don't forget to do the swing guide adjustment & check
              TP08 230d.pdf
              On Finisher Controller switch bits 1,2,5,7 & 8 to on.
              Turn the main power on.
              Press SW103 on the Finisher Controller one time to place the swing guide in home position
              Press SW103 a second time to place the swing guide in the position needed to adjust the downward pressure
              To apply more pressure, press SW102. To apply less pressure, press SW101. Achieving a Gap at [A] (see
              picture below) can be used as a reference point to make sure uniform pressure is applied to the front and rear Stack Ejection Roller.
              Press SW103 a final time. At this time the swing guide will cycle its home position and save the values entered.
              Once satisfied with the adjustment, power off the equipment and switch all bits to zero that were changed in step 2.
              Test the equipment to confirm that the skew is not present by making 20 sets of 5 originals.
              If the skew returns, apply more pressure, but make sure that the Gap at A is not maxed out at the highest position
              If the skew still does not improve additional troubleshooting needs to be performed.
