Canon IR2520 Start up
  • Kings
    Steve@Kings
    • Nov 2009
    • 79
    Hi all,
    Can anybody shed some light on this...Have just gone and installed a Canon IR2520.
    On installation it did not ask to install the toner or go into a toner feed state.
    After trying to force feed the developer by doing lots of blank copies, i managed to get copies out but it then goes into error state E020 (lack of toner)
    I need the information to put it into toner feed mode...HEEELLLPPP Please.
    • 2621
    That's the way I did it but didn't get the error you did, until we got hold of a service manual.
    This is the correct way from the service manual
    service mode / clear / engin / TNRINST
    Supplies toner from the toner cartridge to the
    developing assembly.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      I thought it was Copier>function>install>toner-s
        • 2621
        The cheaper Canons have a different service mode, that's not as good or as easy to use as the service mode that gets discussed on this forum. It requires the same numbers / keys to access it, just in a slightly different way.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Yea I kind of understand now. Those unit IR2520 just hit the states recently.
          They are marketed as IR2525,2530,2535,2545 in the states
          I was taking the course and I came across the service mode functions, and is like that of a IR2020.
          • Kings
            Steve@Kings
            • Nov 2009
            • 79
            Cheers guys, will try service mode / clear / engin / TNRINST Keep ya posted,thanks
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Skynet is correct.
              As I look at the service manual. This is the correct way.
              Cheers.
              • Kings
                Steve@Kings
                • Nov 2009
                • 79
                AHHH got a service manual have ya...Mate, Mate be ya Best mate
                • teckat
                  • 16083
                  "Hoist one for me when you fix it"
                  • Kings
                    Steve@Kings
                    • Nov 2009
                    • 79
                    If i get one your all welcome to it..
                    • victorml.rodriguez
                      Re: Canon IR2520 Start up
                      Hi,
                      A client of mine just got a Canon IR-2525. I have not worked with these copiers, can someone help me on how to access Service Mode. I have installed it, but seem to have a problem with the copied image, it is only giving me about 30% of the original, the rest y plain white, I guess its just toner configuration. How may I access.
                      One of the machines actually is getting paper stuck just before it exits the machine.
                      I hope I explain myself...my english is not very good
                      Thanks!!
                      • teckat
                        • 16083
                        Originally posted by victorml.rodriguez
                        Hi,
                        Thanks!!
                        This printer is not your typical Service mode settings/ it is like a FAX SERVICE MODE settings-
                        U can cause more harm then good -if not trained on this Series-imageRUNNER_2530_2525/imageRUNNER_2545_2535
                        Press > 2 > 8 >
                        to get to Service Mode.
                        Enter service mode by pressing (*)ADDITIONAL FUNCTIONS key followed by 2 key then 8 key then (*)ADDITIONAL FUNCTIONS
                        { each key is pressed separately }
                        You need to Stir toner at setup.
                        Select Service Mode > CLEAR > ENGINE> TNRST> OK. Toner Stir to take approx. 5 minutes to complete.
                        This unit needs a toner stir that is ran through Service Mode during an installation. The Service Mode Toner Stir can be performed by entering SERVICE MODE > CLEAR > ENGINE > TNRINST > OK. The main unit will then stir the toner and will last around 5 minutes and is required for toner agitation. The machine will stop on it's own when complete. The unit can then be tested for image quality after it has completed the toner stir process.
                        The Jam Log is included in the Error Log. To print out a JAM/ERR Log, perform the following steps:
                        Access Service mode>
                        ADDITIONAL FUNCTIONS>2>8>ADDITIONAL FUNCTIONS
                        Scroll until you see "# REPORT" hit OK
                        Scroll until you see "REPORT OUTPUT" hit OK
                        Scroll until you see "ERROR LOG LIST" hit OK
                        Outline of Service Mode
                        The items that follow may be checked/set using the machine's service mode, which is designed the way the service mode used in fax machines is designed in terms of contents and operation.
                        #SSSW
                        Use it to register/set basic fax functions (e.g., error control, echo remedy, communication
                        error correction). Use it to make settings related counter functions.
                        #MENU
                        Use it to register/set items related to functions needed at time of installation (e.g., NL
                        equalizer, transmission level).
                        #NUMERIC
                        These setting items are for inputting numeric parameters such as the various conditions for
                        the RTN signal transmission.
                        #SPECIAL
                        These setting items are for telephone network control functions. Do not use.
                        #NCU
                        These setting items are for telephone network control functions such as the selection signal
                        transmission conditions and the detection conditions, for the control signals sent from the
                        exchange.
                        #FAX
                        Do not use.
                        #SCAN
                        These setting items are for image adjustment in scanning.
                        #PRINT
                        These setting items are for image adjustment in printer assembly and for special mode for the
                        field-related measures.
                        #NETWORK
                        Use it to confirm the contents of the installed CA certificates.
                        #CODEC
                        This is a setting items related to CODEC.
                        #SYSTEM
                        This is a setting items related to SYSTEM.
                        #ACC
                        Register the accessories.
                        #COUNTER
                        Use it to check estimates for maintenance/parts replacement.
                        #LMS
                        Use it to set the inactivity of the transmitted license and the license inactivity without
                        transmitting.
                        #E-RDS
                        This is a setting items related to e-RDS (Embedded RDS).
                        #REPORT
                        Use it to generate reports on various service data.
                        #DOWNLOAD
                        Use it to download firmware to the ROM of a PCB in question.
                        #CLEAR
                        Use it to reset various data to initial settings.
                        #DISPLAY
                        The error and detailed code which have happened now are displayed.
                        Display the engine speed of the main controller PCB.
                        #ROM
                        Displays ROM information, such as version numbers and checksums.
                        #TEST MODE
                        • Hariprasath
                          Can any body to help me to adjust the copy quality in canon ir 2525 service mode
                          • teckat
                            • 16083
                            best to stay out of service mode if u have no working knowledge on product
                            describe your CQ issue----
