iR C3220 NETWORK PRINT [HELP]
  • alexw
    • Aug 2025
    problems in cofiguration, my computer does not find my copier/print....
    1- aditional function,
    network settings
    tcp/ip settings
    ip adress settings
    ip copier/print ...
    10.0.0.3
    ip computer
    10.0.0.2
    the computer not does find copier, i need help ...
    cable ok
  • charm5496
    • 2387
    what do you mean by it doesn't find the printer?
    Are you expecting your PC to go out and auto load the driver for you?
    Have you tried pinging the IP address of your 3220?
    Do the two devies have the same IP scheme, on the same domain?
    You say the cable is ok. Are you connecting straight from your PC to the 3220? If so you need a crossover cable and not a straight RJ45 network cable.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      I think he's using a straight patch cable?
      • teckat
        • 16083
        network settings
        tcp/ip settings
        ip adress settings
        ip copier/print ...
        10.0.0.3
        ip computer
        10.0.0.2
        cable ok
        what are u trying to do ?
        set up network printing ?
        installing firmware ? please explain
        The machine can be connected to a computer or network with a USB (Universal
        Serial Bus) cable, 10Base-T/100Base-TX Ethernet cable, UTP (Unshielded Twisted
        Pair) cable, or STP (Shielded Twisted Pair) cable.
        • ricardobres
          • 147
          The machine is connect with controller? Boot room N or C?
          • alexw
            yeap, boot room N !
            • teckat
              • 16083
              yeap, boot room N !
              so what is the deal/ have u ever used the SST before ???
              • alexw
                The configuration is for impression for the network, simple and without domain.
                the IP in the machine is:
                ip: 10.0.0.3
                subnet mask: 255.0.0.0
                The configuration this correctly !
                the board network OK
                cable Ok
                drive Ok
                but not printed
                • teckat
                  • 16083
                  ip: 10.0.0.3
                  cable Ok
                  drive Ok
                  but not printed
                  When registering firmware for the iRC3220 there is no distinction between N or C version in the Service Support Tool. When you flash the C3220 simply select 'BOOT' and begin the flash process, the Service Support Tool is intuitive and will select the proper version automatically.
                  N BOOT Must have the-Color Network Multi-PDL Printer Kit-it comes with an UFR Board (Ultra Fast Rendering Board) that
                  needs to be installed in the Color imageRUNNER C3200. This board is installed in the slot on the Main
                  Controller underneath the Ethernet PCB.
                  the following Service Mode setting must be changed on the copier:
                  1. Enter Service mode (Additional Functions > 2 and 8 > Additional Functions).
                  2. Select Copier > Option > Int-Face > IMG-CONT.
                  3. Change the setting of IMG-CONT to the appropriate number (0 - 5) as per the following table:
                  IMG-CONT Setting:
                  Device Attached to the Copier:
                  0
                  Canon Controller (Canon Printer Kit)
                  1
                  imagePASS M1 (v1.0 or v1.1), imagePASS L1
                  2
                  TR Systems/AHT
                  3
                  All EFI Color Controllers
                  4
                  All EFI Black and White Controllers (Except imagePASS M1(v1.x) & imagePASS L1)
                  5
                  Not currently used
                  4. Hit OK and reboot the copier.
                  * Note: When the IMG-CONT value is set to any number other then a 0; the network settings must be configured on Fiery device setup.
