force the print with cartridge empty
  • Alessandro72
    • Jul 2009
    • 31
    My IRC 3220 has finished the yellow cartridge and it takes two days to
    receive it.
    Is there a way to have them printed with the warning of a cartridge
    empty?
    Thanks to all of you are always very kind and helpful.
    Alessandro
    https://t.me/pump_upp
  • SCREWTAPE
    East Coast Imaging
    • 3396
    If the machine is asking for yellow toner its not going to print anything until there is a new cartridge inserted. The answer to your question is ,no
    • teckat
      • 16083
      receive it.
      empty?
      Alessandro
      sorry but SCREWTAPE is right /by the way is the message low toner or replace yellow toner ?? if toner low you can print / if replace > you can not / sorry but your customer needs to keep toner on site/ what about overnight shipping
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        I thought you could print B/W still if a color was empty,, just not able to print color???
        • teckat
          • 16083
          hey I forget that / you'r are right / u can set up 3220 to print black only in add functions
          Press the Auto Color Select Button:
          1. Select Black
          2. Select the Additional Function Button
          3. Select The Copy Settings Button and go to the Second Screen
          4. Press the Standard Settings Button
          5. Select Store ( A message will come up asking you if you wish to store this setting.)
          6. Select "Yes" Store in Memory
          7. Press the Done Button
          8. Press the Done Button again in order to go out of the Additional Function
          *****can't recall or remember how to do it for network prints though
          • teckat
            • 16083
            receive it.
            empty?
            Alessandro
            mrfixit just reminded us :
            1. Select Black
            • SCREWTAPE
              East Coast Imaging
              • 3396
              1. Select Black
              But this just sets up the machine to default to black from the machine, it still won't bypass the replace toner cartridge message. As what was mention before , if it only says low toner, then yea you got a couple of more prints. I believe if the machine is asking for toner its not going to change its state. Its not going to do anything until the toner has been replaced.
              • teckat
                • 16083
                good point/ we need to invent a dummy cartridge ??
                • 10871087
                  • Jan 2005
                  • 1062
                  Most machines need color toner to turn on and calibrate so running with and empty cartridge is not possible on just about every machine. ALSO, manufacturers make money selling toner so they don't design the color machines run in b/w with an empty cartridge.
                  • kuby
                    • Oct 2007
                    • 1410
                    Where are you located at Alessandro? May be another dealer will trade out a cartridge with you or sell you a toner.
