Printing from the Mail Box
  • jwcheek
    • Aug 2025
    Working on an Canon IR5020, When we print from the mail box it is moving the copy over about 5mm. When we print straight to the copier it is fine. Was wondering if there is some sort of setting that can be changed to correct this.
  • teckat
    • 16083
    old tech pub:
    imageRUNNER 5000 / 6000 / 5000i / 5020 / 5020i / 6020 / 6020i
    The Copies From the Mailboxes and made off the Glass are not Registered or Sized Correctly.
    The copies from the Mailboxes and made off the glass are not registered or sized correctly. Test prints, P-Prints are OK.
    Solution :
    In this case the Scanner was not moving to the correct read position.Doing the following adjustments corrected the issue.
    Follow through with the adjustments found in Chapter 2 Original Exposure System of the imageRUNNER 5000 service manual.
    * 6.2.2 Routing the Scanner Drive Cable page 2-21R.
    * 6.2.3 Positioning the No. 1/2 Mirror Base with the Mirror positioning tool part number FY9-3009-040 on page 2-22R.
