IRC3220N Yellow & Margenta not printed
  • teohcheehooi
    • Dec 2008
    • 12
    As doing test print PG10.. theres only cyan & black does printed on paper,
    i taken out the yellow & margenta drum to have a clear look on it... & found that the drum surface are out... have replace it once, but few weeks later the same problem occur again...
    Any Idea ??
  • hemai2005
    Professional Print
    • 108
    the causes of this problem ITB,
    check for it,may be will solved
    sigpic
    Learned a lot will become an expert
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Also, HVT, DC controller, ETC. There's more reasons why this can happen.
      • smiley
        • Aug 2008
        • 615
        try to swap the itb assymbly to the working one. next is the hvt. and try to remove the ufr board and try to test pg 10.if magenta and yellow appear replace the ufr board.
        there is no glory without sacrifice
        • teohcheehooi
          • Dec 2008
          • 12
          Thanks Guys.... Will feedback once i solved it. Hav to wait for HVT and DC cont for testing as well.
          • teckat
            • 16083
            Any Idea ??
            swap HVT connectors first to check> swapcyan connector with magenta connector they are next to each together on lower unit
            check the developer bias or the primary transfer roller for each color missing
