I can't find one error, machine is working fine, copy, print etc... There is nothing in the cue indicating problems, whatever was - it has been cleared; shows up after reboot, too. Annoying but otherwise machine is working OK
Canon C1 error light blinking above display, nothing found
is this an imagePress C1 your talking about ??
if so re boot your fiery T1/ or Q1/ a corrupt file will not always show up on screenLast edited by teckat; 03-29-2010, 08:39 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
thanks guys, it is C1 imagepress indeed. It cleared itself up, for no apparent reason; the problem kept sitting there over the weekend manifesting itself with blinking 'error' light over the panel, and nobody claims rebooting fiery; machine was being rebooted a number of times, it didn't help.
Mystery continues, I just don't want it show up again...Comment
Of little help
But if it was blinking all weekend, maybe it did not go away - the bulb may be out.
Completely different machine, but I had a simular issue and it turned out it was an alarm. Go into service mode and see if you have something in ALARM2 (mine was an open door that did not stop the unit from functioning).Comment
Next time @ machine will check the alarm2Comment
*****make sure when u or someone else turns of this printer> to follow the shutdown procedure for this model> i have had clients flipping the power switch on/off with no idea on of the correct way. flipping that switch and not checking the print que causes issues/ u have frustrated users when they have a simple jam> or a job locked up, first thing they reach for is that power switch.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
