clc 3220 firmware
  • micktill
    • Jan 2008
    • 32
    clc 3220 firmware
    is it possible to download the firmware updater for the clc3220 rip not got a problem at the moment but heared they can be a pain like to be prepared
  • teckat
    • 16083
    u mean the imagePass C1 box ??
    imagePASS C1 v2.0 or higher: SYSTEM SOFTWARE INSTALLATION:
    This section will detail a new System Software installation procedure. The imagePASS-C1 v2.0 introduces a network installation procedure for the System Software. PDL Downloader may still be utilized to install System Software.
    Network Installation Method:
    To utilize this network installation procedure, the imagePASS and the computer need to be connected either by a Cross-over Ethernet cable or through a hub or switch with regular Ethernet cables. If connected via the hub/switch, the imagePASS and the computer should be the only two devices attached. All cables should be Category 5 or better and the hub/switch should be capable of 100Base-TX connectivity. The computer that is used for this method should have Windows 2000 or Windows XP, a CD-ROM drive, support for 100Base-TX and approximately 500 MB of Hard Disk space free (if install files will be copied to the computer).
    Follow the steps below to utilize network installation method:
    1. Print out a Configuration page then shut down and power off the imagePASS-C1 v2.0.
    2. Disconnect the network cable from the imagePASS-C1 v2.0 network port. This would be the cable to a customer network, not the Cross-over Ethernet cable that connects to the copier.
    3. Flip the imagePASS-C1 v2.0 mode dip switch 1 (DL) to ON (toward the letters DL).
    4. Connect the computer and imagePASS together either with a Cross-over Ethernet cable or through a dedicated hub or switch.
    5. Power on the computer.
    6. It should not matter whether the computer is set to use a static IP Address or to obtain one automatically.
    7. Insert the imagePASS-C1 v2.0 System Software CD into the computers CD-ROM drive.
    8. Navigate to the CD-ROM drive and double-click on icon for Install.exe. For a faster installation, the files can be copied from the CD to a location on the computers Hard Disk Drive. If this is done, copy the application file and the folder on the CD to a new folder on the Hard Disk Drive. Do not mix the CD files with other files on the computers Hard Disk Drive. The files may be deleted once the installation is complete.
    When the Install.exe utility is started
    10. Power on the copier (which will power on the imagePASS via the PC).
    11. Click the Start button on the installer screen
    13. Click on the Agree button to continue the installation process
    14. The installation process can be checked by observing the indicator on the screen. Although the installation process goes slowly initially, the progress speed will increase as the installation goes forward.
    15. Click the Exit button when the message is displayed that the installation was successful /Remove the System Software CD from the computer.
    16. Power off the copier (which should power off the imagePASS via the PCC).
    17. Dismantle the isolated Ethernet network created for the installation and return the imagePASS-C1 v2.0 to the original network connectivity.
    18. Flip the mode switch 1 back to the original position (away from the letters DL).
    19. Power on the copier (which should power on the imagePASS via the PCC).
    20. Proceed through the normal routine for an initial setup for the imagePASS. Select the proper Language and Market Region, then proceed through Setup to configure the proper settings for Server, Network and Printer. Use the Configuration page printed in step 1.
    21. After the imagePASS reboots, allow it to come to Idle and verify functionality.
    imagePASS C1 v2.1 and lower:
    Parallel Port Method:
    Besides the network installation method described above, installation of the System Software can also be done via the Parallel Port with PDL Downloader (v3.1.4.1 or higher).
    The needed data files can be found on the imagePASS-C1 v2.0 System Software CD in the tftp boot folder (iRC1_V200bot_R.efi and iRC1_V200sys_R.efi). It is recommended to use the USB-Parallel Cable (part # FY9-4154-000 old, FY9-4368-000 new).
    PDL Downloader v3.1.4.1 or higher will allow you to install system software via the USB port on your computer, using a special USB to Parallel interface cable item # FY9-4154-000. This cable can be purchased from Canon, (the PDL Downloader will NOT support any other USB to Parallel interface cable not provided by Canon).
    Be sure to un-install any older version of the PDL Downloaded currently loaded on your computer BEFORE installing the new version PDL Downloader. Un-install any older version via the 'Add/Remove Programs' applet in the Control Panel.
    USB to Parallel Interface Cable Driver Installation:
    The USB to Parallel Interface Cable will not function with the PDL Downloader unless the NetHawk USB-10 Cable Device Driver is installed on your computer. This installation can be tricky.
    • micktill
      • Jan 2008
      • 32
      Thanks for the info I've got six clc 3220 out now so I'm sure it will come in usefull
