Hello everyone!
As the title says, I'm having problems with the Canon IR 1024i photocopier / printer. The problem is: I intended to set it up so, that every employee would have his own access code, but... I made a mistake. I turned on the option to use "User IDs" before I had any IDs set up. Now every time I turn the printer on, it requests a User ID and a password, and it won't let me access the menus without one. Remote control from the computer also requires the same login information.
I googled about resetting the printer to factory settings, but all the advice I got, assumed I could access the menu, usually through service mode. However, trying with the *28* code, the printer simply responds with a double-beep error as soon as I press the (*). Am I doing something wrong here?
The only keys which don't produce the double beep error seem to be "ID", the number pad keys, "OK" and "//". Is there another way to access the service mode or bypass the User ID prompt?
Or possibly a way to do a factory reset without using this mode?
I would appreciate any advice anyone can give, since I'm quite completely stumped.
