GP605 : need help .... copy out very light image
  • xtraez
    • Jun 2008
    • 42
    HI TEAM,
    After runing few thousand printing.. i shutdown machine since the shop close... i turn on back today morning.. found the print out very light ...almost white.. i can see very light shadow..
    Please help..
    Thank you
  • davidj7
    • 1107
    Is the drum hot/cold ?
    Check carona's
    a machine is only as good as your tech : source:screwtape ; the scary one
    • xtraez
      • Jun 2008
      • 42
      Check carona's
      Hi David..
      The machine just started...and idle... so i start the print... print out come out very light... i try few times.. the result still same..
      The corona wire on top or bottom ?
      • xtraez
        • Jun 2008
        • 42
        here the print out after re adjust pre transfer charging assembly... am i do the correct task??.. ...here image Google Docs ..
        please review it.. actual picture is not so dark... my scanner got problem.
