Help!!! E602 - 0004
  • Salam_341
    • Jul 2025
    Help!!! E602 - 0004
    Hi,
    what menas of this ERROR(E602 - 0004) in CANON iR105?????
    I have sst v.4.11E
    I think I want CANON iR105 Frimware,
    But I need HELP
    Seyed.Mohammad.Ali.Ahmadi@Gmail.com
    thanks a lot
  • teckat
    • 16083
    Originally posted by Salam_341
    Hi,
    I have sst v.4.11E
    But I need HELP
    thanks a lot
    Hard Drive error/ check PM
    • Dedy.P
      • 67
      Try using your SST with "HDF"
      • bnmand
        • Sep 2008
        • 383
        Hard drive may need reformatting.
        Then a Hard drive format, then ALL_HDF batch.
        • Raoufselwaness
          Expert
          • Nov 2008
          • 75
          Hi,
          I have sst v.4.11E
          But I need HELP
          thanks a lot
          Hi Seyed:
          did you get my mail??????????
          the answer included
          • JDM
            Possible Workaround
            Hi,
            I have sst v.4.11E
            But I need HELP
            thanks a lot
            Error :
            E602 with Sub Code 0004
            Workaround :
            To resolve E602/0004, you perform HD-Clear of sectors 1, 2 & 3. Enter Service
            Mode, COPIER>FUNCTION>SYSTEM>Highlight CHK-TYPE and set it to "1", next
            Hightlight HD-CLEAR and press the OK button. Follow this procedure for sectors 2 &
            3.
            * See the attached Tech Pub GTI-T158b.pdf for more information.
            • teckat
              • 16083
              sent orig. poster SST info 2weeks ago
