Print out toner leak ir3300
  • jiongpao
    • May 2009
    • 413
    Hi. When i use computer print from ir3300 the wording seems not too stick on the paper once i used my finger to rub it gently. its 230 grams hard cover. A4, 80grams print out is fine
    There is no setting on the computer for ir3300 properties to print hard cover or to select the paper source thickness?
    Im using WinXP, copier driver version PCL5e/5c version 7.10
  • SCREWTAPE
    East Coast Imaging
    • 3396
    1. Go into the properties of the Driver
    2. Select the Device Settings Tab.
    3. Click the Form To Tray Assignment Button.
    4. Highlight everything under Paper Type.
    5. The Paper Types that are selected here, will be available to the user when printing from an application.
    Check out the screen shots
    • davidj7
      • 1107
      are you using genuine canon toner or compatible?
      a machine is only as good as your tech : source:screwtape ; the scary one
