Download STANDBY HELP HELP HELP
  • jshafer
    • Aug 2025
    I have a canon IR1023 it says Download STANDBY Its not normally hooked into the network, last week this same thing happened and I plugged a ethernet cable into it and plugged it into my router and it went away... same thing happened again but this time when I plugged in the cable into the network nothing is happening... ANYONE please help with this is there away to do a HARD RESET on the entire machine. I can't press any button
  • davidj7
    • 1107
    i think youur firmware is corrupted and needs a reinstall.
    a machine is only as good as your tech : source:screwtape ; the scary one
    • jshafer
      and how do I do that... that means nothing to me
      • teckat
        • 16083
        First try re-flashing the imageRUNNER / u need your CD with Firmware/ if lost u need to re order from Canon.
        or u may have a bad DDR Module PCB Assembly
        imageRUNNER 1023 / 1023N = FM2-4897-000
        imageRUNNER / 1023iF = FM2-4898-000
        are u a tech> ????
