ir c3220 firmware
  • aabarnes1
    • Mar 2009
    • 620
    ir c3220 firmware
    Just wondering- is firmware an issue with these machines, as in could digital lines on prints be caused by out of date firmware. I know there are plenty of issues resolved on Kyocera machines with a firmware upgrade. If any of you think it needs to be done could you please tell me how, TIA
    Grant me the serenity to accept the things I cannot change.
  • kuby
    • Oct 2007
    • 1409
    I don't know, what version do you have? And could you post a example of the prints you are getting?
    • teckat
      • 16083
      is it on glass copies,like below > or just network prints ? if on prints, check connectors on DC pcb
      u mean like this=
      • aabarnes1
        • Mar 2009
        • 620
        Here is an example of the prints, you can see those wierd lines
        • aabarnes1
          • Mar 2009
          • 620
          u mean like this=
          [ATTACH=CONFIG]3991[/ATTACH]
          yES YES had a lot of prints like this and a lot of error codes relating to yellow laser. Turned off and on 10 times and it went away, only to return at 5 past 5
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Is this a copy from the the glass.
            Are you using a ADF??
            Looks like your image is streching from the ADF, like when your height is out of spec.
            That's why I ask if you using the ADF.
            • aabarnes1
              • Mar 2009
              • 620
              As I said in the post- it is a PRINT. Those lines you see running the length of the page are one black one magenta and one cyan, interestingly there is no yellow line and yellow laser is the code that keeps popping up. The lines are not caused by pcu, itb or optics- they are digital lines.
              • kuby
                • Oct 2007
                • 1409
                So you are saying that it does not do this when copying from the glass and only when printing from the computer? If that is correct then have you tried a different driver. I had an issue with a church printing their bullentin and it would come out with lines. Had to change to a UFR driver and problem went away.
                • teckat
                  • 16083
                  what are the Laser codes/ u can swap the lasers in this model to isolate problem/
                  Firmware updates have not delt with digital lines/ re check those connectors on DC pcb
                  u can try a Dcon clr/ or reload Dcon/ or reload imagePass C2 Software
                  • smiley
                    • Aug 2008
                    • 615
                    i agre with coby guys if this is shown in printing from computer it is driver related problem i seen this a lot of times when the costumers used pcl driver. upgrade your driver or try use the ps driver.
                    there is no glory without sacrifice
                    • aabarnes1
                      • Mar 2009
                      • 620
                      Yes I know what your saying but the lines appear even on the fiery config/calibration pages- driver not used here. I have reloaded the fiery software twice now . The error code that persistently shows up intermittently is
                      E0001-0110
                      • CanoNiR
                        • 50
                        You'll laugh! But it is well-known defect sensor Cover open
                        Experience is the best adviser!
