Need Helpful advise for IR-C5051, 5035 Toner issue
  • Pickup Finger
    • 14
    Our R&D ask me a question.
    For Canon IR-C5051, 5035 , the machines has a function.
    When the machine is working, If the cartridge do not run out of toner, the cartridges can not be pulled out.
    I think this is a new function Canon placed in the newer model machine but Is there a way to disable this function?
    Eric H.
    • 16083
    Eric H.
    How to open the Toner Container Front Inner Covers to remove the toner containers !!!
    Enter Service Mode and navigate to:
    COPIER > OPTION > DSPLY-SW > Level 2 >< T-CRG-SW> Set to "1"
    Power Cycle the imageRUNNER
    Now enter Settings / Registration > Adjustment / Maintenance > Maintenance >< Replace Specified Toner >
    Follow the on-screen instructions and open the main toner cover.
    Select the [Replacement Needed] tab, and select [Replace. not needed] tab.
    Now all the color toners will be displayed.
    Select the color of the toner to open it's cover.
    Now the [Remove Toner Cartridge] tab will be enabled. Select the Remove Toner Cartridge tab.
    The message [The selected toner still can be used. Do you want to replace it] select YES.
    * The Toner Cover will now open and the toner cartridge can be removed. Follow the on-screen instructions to install the cartridge. *
    **How to display / or hide the Toner Container replacement screen mode in user mode.
    Enter the setting value in service mode LEVEL 2 under COPIER > OPTION > DSPLY-SW > T-CRG-SW to ON [1] or to OFF [0]
    Turn OFF/ON the main power switch.
    Settings / Registration > Adjustment / Maintenance > Maintenance > Replace Specified Toner
    ***** Do not replace toner cartridges until the message prompting you to do so appears.
    • Pickup Finger
      • 14
      Thank you teckat,
      Our R&D department is located over sea, but they got the machine from US, I will pass alone the infomation and have them try,
      Will keep you updated,
      P.S new to this forum, and will keep this in my favorite.
      Eric H.
        • 16083
        Thank you teckat,
        Eric H.
        your welcome, good luck :)
