DADF problem iR2020
  • hemai2005
    Professional Print
    • 108
    DADF problem iR2020
    Dear all
    realy very urgent
    i faced problem in DADF for iR2020 today ,in the first the machine shifted the copy from the edge & then solved by adjusted the setting from the s.mode this is the main problem and DADF ok,then DADF not working probably we will try to solving no no, i remove the DADF & install it in another machine is OK,return to the basic machine ,same problem and not working,if anybody have any ideas about this problem such sensor intiliz. like this or any sol.tell me plz.
    thanks for all in all cases
    sigpic
    Learned a lot will become an expert
  • teckat
    • 16083
    Originally posted by hemai2005
    Dear all
    realy very urgent
    check your original machine RCON/DCON specs
    ??? is the DADF now working from orig issue
    ./ why did u move it after the spec adj worked ??
    • hemai2005
      Professional Print
      • 108
      thanks
      i transfer the DADF to another machine to check DADF working or not and it working fine (teckat)
      the problem solved by remove the three cables between the machine and the feeder and return it again( two times) then everything is ok...
      sigpic
      • teckat
        • 16083
        thanks
        cables can be a problem/ good luck
