IR6020 Lost Scanner
  • ricardobres
    • 147
    IR6020 Lost Scanner
    Hi, I have a IR6020, and when I turn on the machine today, the scan option disappear. I can't enter in diagnostic mode too ( *-28*). I reinstall the system, but, didn't resolve. Some idea???
  • smiley
    • Aug 2008
    • 616
    you should go to service mode aditional function 28 and aditional function again. look for nw-scan it should be 1.
    there is no glory without sacrifice
    • teckat
      • 16083
      why would re install system software for that issue ??
      A loose connection between the Main Controller and the Network Interface Card (NIC) will cause the machine to loose the Scan and Send buttons on the Control Panel. Also, a bad NIC Card will cause this problem.
      *****Reseat the NIC Card first and install a new NIC Card if nessesary.
      Note:
      If the Send button is the only button not displayed, reseat the Riser Card and Resolution PCB on the Main Controller.
      Enter Service Mode by pressing Additional Functions > 2 and 8 simultaneously > Additional Functions.
      Copier.
      Option
      User.
      Scroll to page 3 and select NW-Scan and set this to 1 (the default is 0).
      6) Select OK.
      7) Press Reset to back out of Service Mode and reboot the imageRUNNER
      • ricardobres
        • 147
        Like I said, i didn't enter in service mode pressing Additional function 2 and 8 simultaneously additional function, but I'll try reseat the nic card.
