ir 3300i e602-0004
  • lightningjeremy
    • Jul 2009
    • 139
    ir 3300i e602-0004
    i know that the code is the hard drive, but what does the sub code 0004 mean? my service manual only shows sub codes 0001 and 0002. thanx
  • Hopper
    • 173
    Specific to the i model.
    E602
    0001 A mounting fault of the HDD is detected when the HDD is started up from
    the BOOT ROM.
    0002 A data read fault of the HDD is detected when the HDD is started up from
    the BOOT ROM.
    0003 A sector fault is detected on the HDD.
    0004 A fault is detected in the read /write address for the HDD.
    Main cause The wiring is faulty (short circuit, open circuit). The HDD is faulty. The
    main controller PCB is faulty.
    Action
    1. Wiring
    Are the connection and the cable between connector J1025 of the main con-
    troller PCB and the connector J2005 of the HDD normal?
    NO: Correct the connector/cable.
    2. System software
    Try re-installing the system software. Is the problem corrected?
    YES: End.
    3. HDD, Main controller PCB
    Try replacing the HDD, and download the system software. Is the problem
    corrected?
    YES: End.
    NO: Replace the main controller PCB.
      • 16083
      To resolve E602/0004, you perform HD-Clear of sectors 1, 2 & 3. Enter Service Mode, COPIER>FUNCTION>SYSTEM>Highlight CHK-TYPE and set it to "1", next Hightlight HD-CLEAR and press the OK button. Follow this procedure for sectors 2 & 3.
      ***Warning doing a CHK-TYPE#1 will erase Mailbox Registration
