Maybe he mean that in a second side of paper the copy is cut
IRC 3200 Full colour Print Jam in the Heater Unit..
here is the real image/ if u click and hold on image corner/do a print screen/ copy to paint/ this is what u see/ THE SKEW
Look :>) see upper left corner/ the light gray shadow/click on image to view better
untitled..JPG**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Solid black is just i print out and show you that the shifting....
My Ir105, every second page, will have a bit shifting " not a line"
I try to change all the roller at duplex...but it is still the same..Comment
Yup. wafu you got me the word....Second page being cut...My english is poor...anyway thx..all of you..Comment
Teckat, But when i photocopy from the platen glass also the same...I think it is soemthing to do with the feeder...Any other posibilities?Comment
it is not something to do with the feeder....any posibilities? Paper going into the fuser not smoothly...i will take a pic...then show you...Comment
(it is not something to do with the feeder....any posibilities? Paper going into the fuser not smoothly...i will take a pic...then show you... )
for iR 105> I mean the belts in paper path
#5 Qut.-2- FB6-0484-000
#6 Qut.-1-FB6-0485-000**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Teckat sorry for such a long time din't reply...because sch reopen i just ignore the problem...Right now the back to back skewing problem getting worse but i havent replace the belt....By the way, this picture show that when paper go into the heater unit, sometimes it goes up like this... I have no idea..on what is going on... i think it may related to the skewing...???Comment
But in fact belt are moving smoothly....I will try to get a new set of belt then replace it. By the way, this few code come out when paper jam...0B00,0105,0A10,0209,0110,0104
Sometime the duplex will indicate paper jam, but when open up..nothing inside..put it back few time it become normal...Comment
it all has to do with timing / u are talking about the iR 105 ???
check registration clutches and the registration brake
check = 0110 jam occurs, check the operation of SL3. Also check the linkage to SL3.
CLICK ON PIC
SL3..jpg**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Getting back to the original post...when you rebuild a 3200 fuser you dont have to touch the screws for nip adjustment...i've rebuilt at least 50 of them...follow the documentation...nowhere does it say to touch the screws at all. It is a good idea to check nip after rebuild but i have never had to do nip adjustment if it was correct before fuser was disassembled. New fusers...we are getting alot of them that are misadjusted(wrinkling) right out of the box. The 3200 runs the first 5 copies at a higher temperature...its in the software...thats why usually first copies are bubbled when running some stock(80 lb coated glossy for example). Register the stock in bypass as tracing paper....much better results. I have lots of customers that run double sided glossy(yes i know not supposed to) as tracing paper with excellent results. As for the 105 skewing on the second side,check the duplex flapper for small paper cuts in the guides and fingers. This is very common...will cause jams,skew on second side..also jams on single sided when doing face down deliveryComment
