problems with f1 finisher
  • bindarian
    • Mar 2010
    • 16
    Hello, I have a problem with a f1 finisher on a ir-5020 that has started to give me a problem.
    when you first turn it on the finisher cycles the paper tray goes to the bottom and makes a clicking noise like it is having a hard time returning to the top.If I leave it alone it codes the following : E000540-0001.
    I can help it by lifting up, and it works.Anyone have any ideas?
  • ReproKev
    • 273
    There's a good chance that a sensor in the rear side channel is knocked out of place.
    Remove the back covers and look for a sensor mounted on a plate about midway in the channel.
    • NSCT
      • Feb 2010
      • 50
      Check for backed out screws on the panels and rails. Keeps bins from going back up.
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        The guys are right,, the clicking noise is because the finisher is still trying to lower the tray to "make" a sensor at the bottom of it's travel. If the sensor is dead or knocked out of place that will not occur. This is the same symptom that customers sometimes instigate by placing boxes or garbage cans under the trays, limiting the tray's downward travel...
        • bindarian
          • Mar 2010
          • 16
          Thanks guys! The sensor was knocked loose. reinstalled it and it works great.
          • mrfixit51
            • Oct 2008
            • 1975
            Glad to hear you are up and running!!
            • teckat
              • 16083
              loved chicken steak in Texas, Hotel , for Canon School
