IR3245 printer options
  • Gleq
    • Feb 2007
    • 72
    hi all
    i want to know if bootrom ntype for 3570 will for ir3245
    thanks
  • mrfixit51
    Lead Service Technician
    • 1975
    Originally posted by Gleq
    hi all
    thanks
    No
      • 16083
      hi all
      thanks
      what are u trying to do, build a printer on the side
      • cableties
        • 35
        This model using L M S
        • Gleq
          • Feb 2007
          • 72
          thanks guys.....yae i wanted to move the bootrom from 3570 to 3245 to make it printer and scanner. and could you please tell me where to get the network printer kit for ir3245?
          thanks
          • Gleq
            • Feb 2007
            • 72
            Please cableties what is LMS
            thanks
            • mrfixit51
              • 1975
              thanks
              The bootrom swap will not work.
              PCL/PS Printing is enabled on this copier ONLY through the LMS (License Management System) of Canon. There is no other way! You buy the package from Canon, and then you apply online with the LMS system, placing your group of four 4 bit numbers into their system, along with your copier's serial number. It spits out a group of six 4 digit numbers that you enter into the appropriate spot on the copier. Power the copier off, then on, and set up your network address and you are good to go.
              I believe you can print to the copier using UFRII driver without any licensing. Download the UFRII driver from Canon and give it a whirl...
              • Gleq
                • Feb 2007
                • 72
                mrfixit51 thanks for the insight.
                i'll give it a shot
                  • 16083
                  i'll give it a shot
                  where have u been for 6 months ???
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    Lost...
