copy problem in 6000i
  • karanoberai21
    • May 2009
    • 44
    hi everybody
    please have a look on the scanned images. can somebody help to resolve this problem.
    problem occurs in every 15 to 25 copies. tried changing developer unit, separation carona unit.
  • Brian8506
    • 1664
    I would start with the primary unit.
    • karanoberai21
      • May 2009
      • 44
      i'd also checked primary carona unit. is this problem associate with high voltage trasformer or dc controller.
      • teckat
        • 16083
        Originally posted by karanoberai21
        [ATTACH=CONFIG]4124[/ATTACH][ATTACH=CONFIG]4123[/ATTACH]
        [ATTACH=CONFIG]4122[/ATTACH]
        hi everybody
        could be CCD UNIT
        what about test prints ??
        • Brian8506
          • 1664
          What did you "check" on it? Did you rewire or replace it?
          • waffu22
            • Jun 2009
            • 95
            Try to print a black copy to see if the result is purely black. If not try to change your HVT.
            • karanoberai21
              • May 2009
              • 44
              ya i got the problem in HVT. can HVT be repaired or i would have to change it.
              • kaushikviral
                hi;
                check the registretion cluch or reples
                • teckat
                  • 16083
                  replaced/ call CANON=HVT- FM1-0510-000
                  • waffu22
                    • Jun 2009
                    • 95
                    Try what teckat suggested to you
