iRadv 5045 Add toner
  • roho
    • Mar 2009
    • 844
    Good day! I have an iradv 5045 that is asking for mag toner. I've updated firm ware but the message still appears. Has anybody else had issues with this? Thanks in advance!
  • vidarb
    • Mar 2010
    • 25
    The first models of the ADV 50xx series had problems with the toner hopper unit - but it should have been fixed before the machines went in to production.
    Is this one of the first machines produced?
    Even a broken clock is right twice a day.
    • roho
      • Mar 2009
      • 844
      yes, it is! Have you had this issue?
      • vidarb
        • Mar 2010
        • 25
        No i haven't sorry.
        Not sure what the problem with the first hopper units was either..
        As i can see in my PC the part number for the production hopper is FM3-5981-000 but can not verify this.
        Maybe you can contact Canon for more info?
        • MrB
          • Nov 2009
          • 147
          Know it sounds stupid
          But have you tried adding a new toner cartidge (",)
            • 2621
            Did you open the toner port from the screen or stick a screwdriver to release the catch on the toner door. (*)
            You can display a switch to open the toner cover service mode level2 / copier / option / body / T-CRG SW. If you then go to additional functions / adjustment maintenance / change toner.
            (*) Some of these machines fail to open the toner door when first unboxed and run up.
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              They also want the toner cartridges shaken a bit before loading, I set up a 5030 today that did not like the toner I put in till I took them back out of the copier and shook them back and forth, to loosen up the toner I suppose. After doing so the machine initialized normally.
