iR6570 DADF Trouble
  • bakaoni666
    • Mar 2010
    • 56
    iR6570 DADF Trouble
    Hi,.. Does anyone know how to set dadf in iR6570.
    when i used any size paper the adf sensor become A3. everythings looks normal..
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    Place letter size paper in the entry tray, go into service mode, FEEDER>FUNCTION>TRY-LTR, and press O.K.
    Then place paper guides in LTR-R position in feeder, go into service mode, FEEDER>FUNCTION>TRY-LTRR, and press O.K.
    The items are now set...
    • SCREWTAPE
      East Coast Imaging
      • 3396
      You can also check and make sure that your original detection sensors are set up in service mode.
      Level 2/ Copier/ Option/ Body SENS-CNF = 1
      SENS-CNF =0 (default) : AB Type Document Sensor Placement
      SENS-CNF = 1 : Inch Type Document Sensor Placement
      • teckat
        • 16083
        good ol' level two, all the goodies, and then some >)
        • bakaoni666
          • Mar 2010
          • 56
          thanks...now i can a4 size but when i placed FLSC size it read as A3 ...
          Another trouble... help me
          • teckat
            • 16083
            those DF settings for FLSC need to be adjusted in LEVEL 2 under Copier/ Option/ Body
            in the service mode - COPIER>OPTION>BODY> CONFIG setting
            you will see
            XX= COUNTRY
            YY= LANGUAGE
            ZZ= MANUFACTURE
            AA=PAPER SIZE SYSTEM/ scroll through n' switch this setting for your default paper size
            look for COPIER>OPTION>BODY>SCANSLCT- in some iR's it is Level 2
            set it to 1 (Scan area is determined by paper size) if it set to 0=(Scan area is determined by document detection
            while in there u will see >These are DF Settings to be changed
            ORG-LGL (Used to set special paper size not compatible with DF size recognition.)
            0: LEGAL (value at time of factory shipment/value after RAM clear)
            1: G-LEGAL
            2: FOOLSCAP
            3: A-FOOLSCAP
            4: FORIO
            5: OFFICIO
            6: E-OFFICIO
            7: A-OFFICIO
            8: M-OFFICIO
            9: B-OFFICIO
            ORG-LTR (Used to set special paper size not compatible with DF size recognition.)
            0: LTR (value at time of factory shipment/value after RAM clear)
            1: G-LTR
            2: A-LTR
            3: EXECUTIVE
            ORG-LTRR (Used to set special paper size not compatible with DF size recognition.)
            0: LTR-R (value at time of factory shipment/value after RAM clear)
            1: G-LTR-R
            2: A-LTR-R
            3: EXECUTIVE-R
            Level 2 under COPIER>OPTION>BODY><INT-FACE>
            <CST>
            • U1-NAME (Used to turn paper name display when U1 paper size group is detected ON/
            OFF.)
            0: Display “U1” on touch panel (default).
            1: Display paper name set by “CST-U1” service mode item.
            • U2-NAME (Used to turn paper name display when U2 paper size group is detected ON/
            OFF.)
            0: Display “U2” on touch panel (default).
            1: Display paper name set by “CST-U2” service mode item.
            • CST-U1 (Used to specify paper name used by U1 paper size group.)
            • CST-U2 (Used to specify paper name used by U2 paper size group.)
            24: FOOLSCAP (CST-U2: Default)
            25: Australian FOOLSCAP
            26: OFFICIO
            27: Ecuador OFFICIO
            28: Bolivia OFFICIO
            29: Argentine LETTER
            30: Argentine LETTER-R
            31: Government LETTER
            32: Government LETTER-R
            34: Government LEGAL
            35: FOLIO
            36: Argentine OFFICIO
            37: Mexico OFFICIO
            38: EXECTIVE (CST-U2: Default)
