ir 3300 error 0000 0000
  • naveencopier
    • Oct 2009
    • 26
    hi i am facing the problem in 3300 in fusing unit i have replaced the ceramic heating element also when i replace it the machine will worj for 2 to 3 days after that the problem will be repeted i have replaced 110 volts power supply and dc bord but of no use can any body help
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Sounds like you've replaced all the recommended parts in the manual.
    Have you monitored your wall voltage?
    Can you try a line filter or a different outlet?
