DANKA NX 40 message error
  • rabib
    • 63
    FIERY, DANKA NX 40
    I turn on the FIERY ON and after I see this JUST LOAWDING...
    I want reset the system but I dont have the software and the service manual
    FIERY, DANKA NX 40 (danka 1700 and 1750)
    raja_mustapha_92@hotmail.com
  • rabib
    • 63
    • teckat
      • 16083
      Originally posted by rabib
      FIERY, DANKA NX 40
      i hate DANKA !!!!!!!!!!!!!
      what copier is this piece of junk connected to ??????
      • rabib
        • 63
        INFOTEC C1750 fiery danka
        • teckat
          • 16083
          this FIERY is same as Z40e/Z20e/PS-NX40/20
          “Loading...” hangs on
          the Control Panel.
          Prob Cause:
          ColorPASS system software
          is corrupted or not
          installed on the hard
          disk drive.
          Action to try:
          Restore the system software backup using the
          Restore Backup function from the Service
          menu.
          • If the problem persists, install system software
          from the CD.
          Prob Cause:
          Cable connections to
          the HDD are loose or
          faulty.
          Action to try:
          • Check cable connections to the HDD.
          • If the problem persists, you may need to replace
          the HDD cable or the HDD.
          or try and do a clear server, on Fiery menu buttons
          or u better re load the Fiery software
          • rabib
            • 63
            thanks teckat
            I have ps-nx40 I format the HDD
            rabib
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              To format the hard drive without the system software for the device is a no-win proposition. At this point you have to secure the software for the device, or all you have is an over sized doorstop...
              • teckat
                • 16083
                thanks teckat
                rabib
                why ? if u did format without a CD of the software ??
                i did not post for u to format the HDD/
                hope u just cleared the server/ or tried to
                Restore Backup function from the Server
                that software is difficult to obtain/ hope u know someone who has it/ if not, u better call CANON or DANKA sales
                dept or post for it
                like mrfixit posted/ u now have a useless piece of hardware !!!!
                • rabib
                  • 63
                  hi teckat
                  hi mrfixit51
                  I install the win NT4 PLUS THE softwares (Fiche produit : NX 40) but I board find the same problem .
                  • teckat
                    • 16083
                    hi teckat
                    hi mrfixit51
                    that is not the FIRMWARE u need >that link is for those APPS / & print drivers
                    U need the NX 40 system software FIRMWARE/ call a DANKA sales rep. in your area/ tell them u need the nx 40 system software
                    • rabib
                      • 63
                      thanks teckat
                      This firmware is not available in internet or someone who has already :?????????? pleeeezzzzzzzzz
                      • teckat
                        • 16083
                        u can post for it in FORUM/ or call DANKA sales/ network tech support in your area
                        it is not available on line
                        • rabib
                          • 63
                          software for danka nx-40
                          • rabib
                            • 63
                            plezzzzzzzzzzzzzz
                            • teckat
                              • 16083
                              plezzzzzzzzzzzzzz
                              post for it on main forum under CANON/
                              FIERY software is same as Z40e/Z20e/PS-NX40/20
