IRC 3220 screen going black and freezing problem and FIX
  • shout_print
    • Sep 2009
    • 18
    Our 3220 started to occasionally reset and progressively got worse. With the screen going black and the machine shutting down
    It seamed to be heat related and I suspected a dry joint on the Fuseboard or powersupply
    There where several bad looking joints on the fuse board, I reflowed the solder.
    Problem Fixed
  • teckat
    • 16084
    Problem Fixed
    warning >better replace that crappy fuse pcb/ will cause future problems
    take it or leave it :>}
    • SCREWTAPE
      East Coast Imaging
      • 3396
      I agree. Short cuts cost more in the end.
      Don't be penny pound foolish, Trust us, its word from the wise.
      • teckat
        • 16084
        that Fuse pcb is the worst i have seen in 20yrs w/Canon- now that i think about it>maybe the NP400/500 fits in there/ ah' yes and also the CLC1
        • shout_print
          • Sep 2009
          • 18
          WOW how can such a small simple board be so much trouble
          What wil replacing it do ?
          wont the new board end up the same way ?
          • SCREWTAPE
            East Coast Imaging
            • 3396
            What will replacing it do ?
            You have proven to be quite a tech by resoldering
            But save your time and trouble.
            • tricotech1
              • Feb 2010
              • 40
              You could always send it to Hytek in Florida. Repair price is cheaper than ordering a new one and you get a year warranty on it. Just a thought.
              • teckat
                • 16084
                HYTEK is a ripoff/ if u tell them a board is bad n' it's good , u still pay
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Hytec is could for certain things when you don't have to pay, but the price difference isn't much if you were to purchase a new part from canon.
                  • tricotech1
                    • Feb 2010
                    • 40
                    That is true. If you blindly send a board to Hytek, they will charge the repair price for that board. BUT, if you ask for the board to be tested first and it tests good, they will only charge a bench test fee, around $33 I think. I just sent a Reader controller PCB for testing and they only charged me for a bench test fee, but I had to contact my Rep first and assign an RMA on the outside of the box. I had a scanner that was intermittenly stuttering. I wanted to be sure if I replaced the motor, that I didn't have a damaged board also. It pays to be careful.
                    • teckat
                      • 16084
                      here u , always request test first, a lesson well learned
