My c5185 doesnt have universal send, how is that possible???
  • crwoo
    • 76
    Hi, i recently bought a canon c5185 on ebay and it doesnt have the universal send. there is no send button on the copier. I thought universal send is standard and not optional on that copier.
    Could it be dissabled?
    Should i contact the seller and demand it, or is it optional on my machine.
    I have it on a C3220 that i dont need, could i transfer it to my new copier?
  • teckat
    • 16083
    Standard on iR 5185/5185i
    they may have had eCopy on it before
    check-in service mode -Level 2
    ***To turn the Send UI back on go to service mode level 2 copier/option/body/ UI-EXT or UI-SEND turn this from 0 to 1 and your send tab should be back.
    Enter Service Mode by hitting Additional Functions, 2 and 8, and then Additional Functions.
    2. Hit COPIER > DISPLAY > ACC-STS and view the value for SEND.
    3.If a 0 is displayed for SEND, then the Send function is absent, if a 1 or 2 is displayed for SEND, then the Send function is present.
    Make sure Dept ID is off in Additional Functions > System Settings > Dept ID >
    Also check that Limited Functions is off>in >additional function>, common settings
    no u cant transfer
    • D_L_P
      Self Employed
      • Oct 2009
      • 1196
      I hate to be the bearer of bad news but PDF universal send only comes standard with the "i" series. Technically yours does have uni send standard, but it is the trial kit B1.
      You will need to add one of these:
      1323B002AA uni send advanced PDF feature
      or
      1324B002AA uni send secure PDF feature.
      • teckat
        • 16083
        or
        basic color send is standard in 5185/5185i-
        we know that, about pdf advance / but poster is not asking that question
        The Universal Send PDF Advanced Feature Set-A1 includes Searchable PDF mode, Trace & Smooth PDF functionality, and PDF High Compression Mode.
        - The Universal Send PDF Security Feature Set-A1 includes Encrypted PDF mode and Digital Device Signature mode.
        • crwoo
          • 76
          interesting... i cant find much info on ecopy. i want a simple and quick way to scan to mac and pc. what would be the best option for me?
          Thanks for the quick replys. i will check if ecopy is enabled
          • teckat
            • 16083
            eCopy is sep APP
            http://www.ecopy.com/products_ecopy_desktop.asp
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              While well worth the money, eCopy is far more expensive and complicated than Universal Send.
              FYI... Just in case anyone needs to know, the trial version of Universal Send is only good for a total of 100 scans, regardless of number of pages or time frame. Plus you can't install the trial version more than once (tried that...got bummed...).
              • crwoo
                • 76
                thanks techkat, it was dissabled in settings.
                Will i only be able to scan 500 pages??
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  If you got universal send up and running, you should be able to scan what ever you want. There's really no limit.
                  • teckat
                    • 16083
                    u can scan until the end of time/next time>
                    • togrok
                      • Jun 2009
                      • 24
                      Hi,
                      Anyone know where Canon moved the Universal Send Demo to help set it up?
                      Thanks,
                      Bob
                      • teckat
                        • 16083
                        Originally posted by togrok
                        Hi,
                        Thanks,
                        Bob
                        what Demo are u talking about
                        Call a Canon Authorized dealer/ to set up a Demo on Product/ Have u purchased it for iR5180
                        • togrok
                          • Jun 2009
                          • 24
                          There was a page on Canon's site that let you go through all the functions of the Universal Send. We resell C3200's and I used this site to help our Customers set it up.
                          • teckat
                            • 16083
                            I'll see if i can find it
                            imageRUNNER Universal Send>
                            double click on pics>>
                            1. Select the “Send” tab from the
                            touch-panel display.
                            2. Press [Fax],** [E-mail], [I-Fax], [File],
                            or [Store in Usr Inbox] to manually
                            input the destination. Or select
                            the desired destination from one
                            of the following:
                            • Address Book
                            • Favorites
                            • One-Touch
                            • LDAP Server
                            (Network Address Book)
                            3. Adjust settings as needed:
                            • Scan Settings: Press [Option] for
                            the Scan Settings screen. Press
                            [OK] when all Scan Settings have
                            been specified.
                            - Color Mode
                            - Resolution
                            - Copy Ratio
                            - Document Size
                            - Scanning Mode
                            - Copy Exposure
                            - Original Type
                            - Special Features
                            • Two-Sided Original
                            • File Format
                            • Divide into Pages
                            • Send Settings
                            4. Press [Preview] then [Start] to show
                            the document preview.
                            5. Press [Start Send] to begin the
                            Send. Or, if [Preview] was not
                            selected, just press [Start] to
                            send your document to the
                            selected destination(s).
                            On black-and-white imageRUNNER
                            devices,
                            Universal Send supports TIFF,
                            MTIFF, and PDF.
                            On Color and color-enabled
                            imageRUNNER devices,
                            Color Universal Send
                            supports these file formats, plus JPEG and
                            PDF (Compact). On the new imageRUNNER
                            70 Series devices (Color and B/W), Universal
                            Send also supports PDF (OCR) (optional)
