Canon IR3320i
  • tibbs
    • Aug 2008
    • 225
    Canon IR3320i
    Hello, i have a problem with a Canon IR3320i that when i press the start key it says printing has been completed and nothing happens. I have put in a new hard drive and loaded the latest system software but i get the same problem.Anyone can give me any info on this problem.
    Thanks in advance.
  • charm5496
    • 2387
    does this unit have a fax board installed?
    If so unplug it from the machine and bring the copier back to a ready state and test again. I have had the fax board go bad and cause the same exact issue you are fighting.
    • tibbs
      • Aug 2008
      • 225
      Thanks much, it was the fax board causing the problem.
