Canon Imagepress C1 - Close the front cover of the finisher (E00713-000)
  • Marcos
    [Error Code] Canon Imagepress C1 - Close the front cover of the finisher (E00713-000)
    Hello,
    Since this morning our Imagepress C1 displays the warning: 'Close the front cover of the finisher'.
    It comes with the error code: E00713-000
    Is anyone familiar with this problem?
    We believe that it has something to do with the sensors, we've tried everything, from closing the
    door a thousand times to shutting the power off completely, but we can't seem to solve the problem.
    Thanks in advance,
  • SCREWTAPE
    East Coast Imaging
    • 3396
    E713 is a Finisher / Printer communication error
    Maybe you have a blown fuse pcb or a bad finisher controller pcb.
    Remove the finisher from the machine to verify that the machine is okay.
    If so, then focus on the finisher.
    • teckat
      • 16083
      Originally posted by Marcos
      Hello,
      Thanks in advance,
      The Finisher, the Reader and the Pedestal / Cassette Feed Unit all communicate through the Cassette feeding Unit / Pedestal Controller to the print engine. If the print engine looses any communication to any of these accessories one or more error codes will occur intermittently.
      Finisher Controller PCB / check & re-seat connectors on it
      Re seating the connections on the De Curling Controller PCB
      check the MOLEX connector on pedestal
