ir 3570
  • idanmen
    • Aug 2025
    ir 3570
    how to connect ir 3570 with wireless lan, i need that for conection printer. . .
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Connect the machine to the wireless router.
    You would still have to hard wire the machine.
    Set up the machine with a IP address and then you can print from your wireless laptop or work station if it has a wireless card.
    • idanmen
      can you explain it, more explicit tanx
      • SCREWTAPE
        East Coast Imaging
        • 3396
        You take a patch cable connect it to the machine. Connect the patch cable to port on the wireless router. Configure the machine with a ip address, ping that ip address from the computer to make sure you have communication. Add the print driver, set up a standard TCP/ip port with the ip addess you gave the machine, continue to install the print driver.
        • PoonKing5000
          • Jun 2008
          • 111
          Or if you want to make the copier wireless you could use a wireless gaming adapter like a Linksys WGA600N or Wireless Bridge WET610N.
          • teckat
            • 16083
            speaks for itself
            WET610N Wireless-N Ethernet Bridge with Dual-Band
