Amazing. This is the exact kind of information i have been looking for. as i said before, i am not at the office anymore and will have to try this in the morn. one more question. Do you have to set SMTPRXPN 587 as well? or should i just leave that at 25?
IR C3220 Gmail setup
ALTpmTech
Ok, So now that makes me wonder if it is caused by the pop account. Never thought about that. I will have to try to remove the pop and see if it can at least send. I not sure if there is an imagepass installed or not. so i will have to check that for sure. I do know i can go into the second level and change the smtprxpn and txpn. just not sure if it is doing anything. I guess we will have to find out tomorrow if it works.
Lately there have been lots of requests on our imageRUNNERS to use GMAIL as the SMTP Server. Here is the info from mail.google.com.
Configuring other mail clients
The Quick Answer
- Follow the instructions below to set up POP access in most POP clients.
- Google Apps users, please follow the default instructions unless otherwise noted, replacing 'your_domain.com' with your actual domain name.
- We offer instructions for configuring some clients not in our supported client list. If you encounter difficulties, we suggest contacting your mail client's customer support department -- we're unable to provide assistance for clients not in our supported POP client list.
- G MAIL Supported POP client list
- Mail Clients
- Apple Mail 3.0
- Outlook Express
- Outlook 2002
- Outlook 2003
- Outlook 2007
- Thunderbird 2.0
- Windows Mail
- Other
- Once you've enabled POP in Gmail, you can configure your mail client or wireless device to download Gmail messages. To see our recommended settings or troubleshoot POP issues, click the name of your mail client or wireless device below.
If your mail client isn't listed here, we're unfortunately not yet able to provide assistance with its configuration. - Non-supported clients:
While configuration instructions are available, we're currently unable to provide support for these clients. - Entourage 2004
Entourage X
Eudora 5.1 (and higher) (Light Mode)
Eudora 5.1 (and higher) (Sponsored & Paid Mode)
Eudora for Macs
Foxmail 5.0
Mozilla 1.7
Netscape Mail 4.5, 4.6, or 4.7
Netscape Mail 6.2
Netscape Mail 7.x
SnapperMail
The Bat! v3.62 Professional Edition
Thunderbird 0.x - Standard instructions:
- Enable POP in Gmail. Don't forget to click Save Changes when you're done.
- Configure your client to match the settings below:
- Incoming Mail (POP3) Server - requires SSL:
- pop.gmail.com
Use SSL: Yes
Port: 995 - Outgoing Mail (SMTP) Server - requires TLS:
- smtp.gmail.com (use authentication)
Use Authentication: Yes
Use STARTTLS: Yes (some clients call this SSL)
Port: 465 or 587 - Account Name:
- your full email address (including @gmail.com or @your_domain.com)
- Email Address:
- your email address (username@gmail.com or username@your_domain.com)
- Password:
- your Gmail password
- Unless you're using recent mode to download mail to multiple clients, make sure you've opted not to leave messages on the server. Your Gmail settings determine whether or not messages stay on the server, so this setting in your client won't affect how Gmail handles your mail.
Please note that if your client does not support SMTP authentication, you won't be able to send mail through your client using your Gmail address.
Also, if you're having trouble sending mail but you've confirmed that encyrption is active for SMTP in your mail client, try to configure your SMTP server on a different port: 465 or 587. - You're now ready to use POP with your Gmail address.
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
ALTpmTech
So after doing a full reset of the printer and setting everything back to factory defaults we reentered the information but omitted the pop.gmail.com information. Just the SMTP info. It worked. Easy fix after all. Thanks again guys for all the help.Comment
Cheers.Attached FilesComment
Wis
What I want:
Automatically print every mail that comes into the mailbox (google apps) the printer uses. Printing attachments is not needed.
Is that possible?
If that is possible please help me with the questions at the bottom of the page.
The System:
The printer in use is a Canon CLC 3220 C1 with firey, send kit, no fax kit.
The Software used for configuring the fiery is Command WorkStation 4. I've tried to use Command WorkStation 5 on XP and Win 7, but it seems to me it is not fully compatible with ImagePass C1.
The only network settings aktiv are at the moment ethernet with 100 Mbs, static IP and static DNS. The eMail is inaktiv.
The Ports for the Printer were changed in service mode pop is now 995 and both smtp settings are 587.
The network has a range from 10.10.10.1 to 10.10.10.254
So here are my questions:
I had no luck using URL for connecting to gmail and the dns settings in the fiery are pointing to the router AVM Fritzbox and to 213.73.91.35 (dnscache.berlin.ccc.de). Usually this does work, are there some limitations for the 3220 concering the dns server?
It does send mails but it takes at least 8 minutes to send a b&w 200x200 one page pdf file. Even when it uses the ip for gmail smtp Is that normal?
Setting up the pop3 connection via additional fuctions does not work for me. I've set it to standart authentication and ssl, the pop server to the fitting ip and changed the port in service mode to 955. But it does throw an error when trying to connect fails.
Also I don't know were the error log for the send errors is?
How do the settings of the fiery interact with the printer settings. Does one overrule the other?
As I do understand the previouse posts it is not possible to change the ports of the fiery and so I've deactivated its mail feature and use the send kit instead, is that correct?
I've tried to set this up for several days and have no more ideas.
Please help!Comment
To make Outlook print emails automatically as they are retrieved:
- Select Tools | Rules and Alerts... from the menu in Outlook.
- Click New Rule....
- Highlight Check messages when they arrive under Step 1: Select a template.
- Click Next >.
- Check a criterion if you want to print only certain messages and make sure you fill in the variables under Step 2: Edit the rule description.
- Click Next >.
- If you specified no filtering criteria, click Yes.
- Check print it under Step 1: Select action(s).
- Click Finish.
- Now click OK.
9 Gmail Tips That Will Let You Take a Long Lunch - PCWorld**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Wis
1. Not question asked.
2. No Answeres that include setting up anything but the printer.
3. Your answere is appreciated, but I've set my mind. At least until someone states and explains why what I want is impossible.
Sorry I'm a bit edgy, but when ever I post something people tend not to answere what is asked but what they think would be best to do instead.Comment
You show only two posts ?
Your best bet would be to call a Canon Authorized Service Company- and ask for their Networking Service Support people.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Wis
I'm referring to a general problem not confined to this forum. Maybe its just me or my way to ask questions.
Since People stopped this discussion after gaining smtp access i had the hope that they easily achieved what I seek for.Comment
