IR C3220 HDD Format
  • ZOOTECH
    Senior member of CRS
    • 3375
    IR C3220 HDD Format
    We are mainly a Sharp dealer and have a Canon IRC3220 as a trade in which we are going to donate.
    What is the SC to format the HDD and how do I access the SCs? Thanks in advance.
    • 16083
    First u need the iR 3220 Firmware/ and the Canon SST tool, to format & re load Firmware
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Why do you want to format HDD if your gonna donate the machine??
        • 16083
        A Better Way'
        • D_L_P
          Self Employed
          • Oct 2009
          • 1196
          You can format some of the HDD partitions, but this just deletes the file registry. It will not wipe the HDD clean.
          Press * (additional functions), press 2+8 simultaneously, then press * (additional functions) again. You should see service mode now, press Copier->Function->System.
          Select CHK-TYPE. Press 1 and hit OK.
          Select HD-CLEAR. Press OK.
          Select CHK-TYPE. Press 2 and hit OK.
          Select CHK-TYPE. Press 3 and hit OK.
          1=image storage partition, 2=general file storage partition, 3=PDL file storage partition. 4=firmware partition and 0=all partitions, but 0 or 4 won't work from service mode. You can select them and do the clear but no formatting will actually happen.
          NMFaxMan had a good suggestion, buy a preloaded HDD from Nationwide repair service and give them their old one.
            • 16083
            it makes no sense for poster to Format a HDD on machine their are donating / unless they got it from Microsoft/Apple/ or it has the COKE formular
            • ZOOTECH
              • 3375
              Thanks D_L_P, I wanted to clear any document storage that the previous customer had saved.
                • 16083
                Be careful while in service mode
