E353 of canon cp660
  • remielee
    Technical Analyst
    • Mar 2010
    • 140
    E353 of canon cp660
    sir on my previous post canon cp660 about the error message
    = "schalten sie das system (rechts am scanner) Aus und wieder Ein."
    ="treten trotz obiger mabnahme fehler auf. trommeleinheit ersetzen"
    TRANSLATION BY GOOGLE:
    ="They turn the system right at the scanner off and on again"
    ="Despite the errors occur on those placed replaced drum unit"
    now theres a new error message with code apear when i try to clear the error on the service mode function, close then and on the machine it gives me
    ="Schalten Sie das System (rechts am Scanner) Aus und wieder Ein."
    then E353
    do you know what is this mean guys? i try to search and read the service manual about the said error code but i cannot find it.any help would be appreciated and respect with gratitude.thank you very much in advance..
    anyway thanks sir teckat for the manual...still fixing the machine hope it will be ok soon....
