Hello,
now i have a new problem with the Canon IR2570Ci Copier/printer
The copier says that i have to install a new yellow toner catridge.
Ok, i followed the replacement menu and changed the cartridge with a new one... but this machine give me the same error again: "install a new one toner cartridge", the yellow one of course.
I made the same procedure again with the same, new cartridge. NG result. I tried to remove a Y developing unit and cleaned a unit's contact. ATR sensor and shutter also were cleaned. After installing the unit back to the copier and yellow toner inserting..... TADA!
copier show that yellow toner is full. Unfortunately after few copies was made the mashine gave me an error on the UI screen E0000020-01a2. According to the SM this error means that problem is In ATR control, SGNL is 960 or more. What does that mean and what I should do next ???? There is copy/print quality problem too, the broad yellow stripe (about 3" wide) is present on the copies.
