Image Press C1 error code E000007-007
  • COCODIAZ
    • May 2010
    • 31
    [Error Code] Image Press C1 error code E000007-007
    I have this error code, can help me please.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Your lower fixing belt is walking.
    When was the last time the fixing unit was rebuilt.
      • 16083
      Reads as E007-007
      E007
      Belt displacement error
      0007
      Detection of displacement error by the double error detection
      The fixing belt may be displaced while rotating.
      Turn the gear until it stops.
      [B]If turned in the direction shown by [A], the fixing belt shifts closer to [a] when turning the belt.
      If turned in the direction shown by [B], the fixing belt shifts closer to when turning the belt.
      Turn the belt to shift the fixing belt to the center position.
      After placing the fixing belt position to the center, turn off and then on the power.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Also after replacing the belt make sure to apply silcon oil to the marked area of the pressure pad cover.
        There is a 100K QA Kit: F02-5812-000. When ever I rebuilt the fixing unit I use the QA kit.
          • 16083
          If u have never replaced belt / get a manual/ or ask for
          • COCODIAZ
            • May 2010
            • 31
            Thanks guys, i never replaced belt, and dont have manual. But I turn the belt to shift the fixing belt to the center position and work ok
            Have to replace the belt ?
              • 16083
              Thanks, good work
              fixing belt= about 100,000K under normal conditions
              • SCREWTAPE
                East Coast Imaging
                • 3396
                Gald your up and running.
                Do not attempt to do any work on the fixing unit if your not sure how too.
                Let a professional tech do it. You got lucky this time.
                  • 16083
                  SCREWTAPE is on the Money
                  call for help or suffer the consequences
