IR C2380 - 839 Error Code
  • Tiago
    This is my first post on this board but it looks like an excellent place to discuss this problems.
    I have a IR C2380 that receives Faxs but is not sending to the e-mail address I specify. I had #802 error code but I changed the hostname of the SMTP server to its IP and now I have a 839 error code that I don't know what is it.
    Can anybody help fixing this problem?
    Thank you.
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Does the SMTP server require authentication? If so you need to add it in the additional functions ->system settings ->network settings ->e-mail/Ifax. The 1st 2 boxes need filled in and then touch the auth. button to add the credentials if needed. You don't need a valid e-mail address in the 2nd box but it does need some email there, put copier@whatever.com.
    • Tiago
      Thank you for the reply. It look like the fields are all good.
      Let me explain you my problem, maybe you can see the solution by reading it.
      Our e-mails were being hosted by a web development company. To save the price of the service (just hosting and e-mails) we subscribed for a shared hosted solutions, change the e-mails SMTP servers in Outlook and everything works OK for the e-mails.
      We have the email fax@mydomain.com (which we add in the canon machine as the FROM and TO) hosted in our shared host and on theirs. We still have the contract with the web development company so we can test with their servers. If I put their SMTP servers on the Canon machine and set the e-mail in Outlook with their servers as well, everything works fine.
      When I change the SMTP server on the FAX machine to ours and in Outlook to ours as well, it doesn't work.
      Another funny thing is that when I set the FAX machine to send FROM fax@mydomain.com using their servers and, setup the Outlook to receive with our servers, it gives a 839 error (mail sent by multiple servers).
      We are running a server with Windows Server 2000, maybe I need to give authorization for that SMTP server? But if that's the case, how come the e-mails work fine?
      Thank you. By helping me you are saving my father's company big bucks that we don't have at the moment.
        • 16083
        Originally posted by Tiago
        Thank you.
        #839 [SMTP] Sending to e-mail server
        user name or password for the SMTP server
        authentication (SMTP AUTH) does not match.
        Check and verify the user name and password for SMTP
        authentication (SMTP AUTH) are configured properly in
        ADDITIONAL FUNCTIONS > SYSTEM SETTINGS >
        NETWORK SETTINGS > E-mail/I-Fax >
        Authent./Encryption.
        **use Microsoft Outlook Express (DO NOT USE OUTLOOK) to test, verify and confirm the correct requirements for the E-mail
        server that the customer is trying to use to send E-mail. You can bring up Microsoft Outlook Express by clicking START > RUN then
        type MSIMN and click OK. Then create an E-mail account using the information that was provided to you and try to send an email
        from MS Outlook Express.
        #802 [SMTP] Sending to e-mail server
        SMTP server name is not properly configured in
        Additional Functions.
        -Connection to the DNS server failed.
        -The SMTP server IP address is not properly configured in
        Additional Settings.
        Check and verify that the correct SMTP server name is
        configured in Additional Functions.
        -Check and verify that you are using a valid DNS server
        that has the correct name resolution to that SMTP server.
        -Check and verify that the correct SMTP server IP address
        is configured in the Additional Functions.
        • Tiago
          Thank you very much! It worked.
          • mrfixit51
            Lead Service Technician
            • 1975
            Glad to hear that you have the problem resolved,,, what did you actually change that fixed the problem?
            • Tiago
              I just changed the SMTP server to one that didn't require authentication.
              • D_L_P
                Self Employed
                • Oct 2009
                • 1196
                Glad to hear you got it fixed.
                • Tiago
                  Originally posted by D_L_P
                  Yes, I'm curious as well. Did you turn on authentication for your SMTP server or turn it off at the copier?
                  I just talked with my hosting company and they gave me a SMTP server that doesn't require authentication. The problem is I can only send e-mails inside my domain, but for me that's ok.
                  No more than that, just inserted the SMTP server with no user and no pass.
                  • D_L_P
                    Self Employed
                    • Oct 2009
                    • 1196
                    Good to know.
                    If you want to use your server to send outside your domain your server needs a static public IP, your ISP's DNS servers added, and setup the MX record. It can be a security risk since your server would be exposed directly to the net. You might find some articles on support.microsoft.com on the best way to set it up.
                    An alternative would be to use a public SMTP server like google mail, smtp.gmail.com.
                      • 16083
