IR 2022 printing problems
  • Dalamar
    • Oct 2006
    • 117
    [Misc] IR 2022 printing problems
    when print jobs are sent the machine it asks to change the paper type, however the machine and the print drivers are set to plain paper. if you pull out the tray and slide it back in its starts printing.
    any ideas on how to remedy it?
    Notatechie - "I am trying, but I don't know how to go into Service Mode. If I just go in and press *then 2, than 8, then * it does not do anything."
    SCREWTAPE - "Try harder.."
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    I see this a lot on the larger copiers, the print driver is the one that is not happy. The copier is fine. Try to choose the paper source, such as cassette 1, instead of auto, and I believe it will work o.k. You don't happen to have the paper "type" settings for the cassettes set to anything other that plain paper under Additional Functions on the copier do you?
    • teckat
      • 16083
      'Paper is not correct. Change paper.'
      error message can be caused by a broken or misaligned Position Block (shown below, Figure 310/312 in the Parts Catalog). If the cassette does not seem to be locking into place, this part may be the cause. In some cases, applying pressure to the front of the cassette will temporarily alleviate the problem.
      click on pic for better view-
      also check Size Detection Assy. { FM2-3319-000 }
      also Check -User Mode Item/ listed under Common Settings > Register Paper Type.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Look at your printer driver settings.
        Is your driver register to the 2022?
        • Dalamar
          • Oct 2006
          • 117
          [ATTACH=CONFIG]4581[/ATTACH]
          I think we have a winrar , I'm going to check it out tomorrow and let you know what i find out. I should have mentioned in my original post that it wasn't the print driver..... machine has held up pretty well until recently, customer bought it new almost two years ago and so far it has 520k on it.
          • D_L_P
            Self Employed
            • Oct 2009
            • 1196
            I agree with MrFixit and Screwtape, check your print driver. Lock it into drawer 1 if you can.
            If opening and closing the drawer will force it to print, try turning on the auto-continue feature. I don't know off the top of my head where it is but it will be in user mode under printer settings.
            What application are you printing from?
            Winrar is a file extractor utility, similar to winZip only .rar are compatible with any OS.
            • mrfixit51
              • Oct 2008
              • 1975
              Am I the only one who is confused here??? What does Winrar have to do with printing problems??
              • teckat
                • 16083
                hardware check is first order of issue
                • D_L_P
                  Self Employed
                  • Oct 2009
                  • 1196
                  It confused me too. I wasn't sure what winrar has to do with printing either.
                  • teckat
                    • 16083
                    think poster means "winner"
                    • D_L_P
                      Self Employed
                      • Oct 2009
                      • 1196
                      I think you are right! LOL
                      We need some sort of code breaker machine for some of the posts on this site!
                      :/ Teckat could come up with a better picture maybe
                      • teckat
                        • 16083
                        At your service~~~~~~~~:
                        • Dalamar
                          • Oct 2006
                          • 117
                          Dear mr. teckat
                          Winrar - Someone who wins. The polar opposite of fail.
                          • D_L_P
                            Self Employed
                            • Oct 2009
                            • 1196
                            LOL
                            Thanks for clearing this up!
                            • teckat
                              • 16083
