Image Runner 2525i with Mac OS 10.4
  • delacelle
    • Nov 2008
    • 7
    Hello,
    do somebody as an experience on set up a printer canon IR 2525i on MAC OS 10.4
    Here, in france, CANON answer me it's not possible yet.
    But :
    1 This printer come to replace an old IR2800 who worked fine with Mac OS 10.4
    2. there is a driver available from CANON web site
    3. I cannot belive that this printer does not support the Mac OS
    thank you for any answer
    Cedric
    See the sky !
  • teckat
    • 16083
    Originally posted by delacelle
    Hello,
    But :
    Cedric
    Check the Canon USA support site/
    UFRII V1.80 SHOULD WORK
    UFRII v1.80 Printer Driver for Macintosh OSX
    UFRII v1.80 Printer Driver for Macintosh OSX 10.5 supports the Power PC: Mac OS X v10.2.8 to v10.5 & Intel: Mac OS X v10.4.4 to v10.5. This driver adds support for the Color imageRUNNER C2550/C3080/C3480, imagePRESS C6000/C6000VP, and Color imageRUNNER LBP5970/5975.
    Printer Driver for Macintosh OS X
    Mac CUPS UFRII v2.00
    Mac CUPS UFRII v2.00 Printer Driver for Macintosh OSX Supports Mac OS X v10.4.9 to v10.6.0 This driver adds support Mac Os X v10.6.0 (Snow Leopard).
    • D_L_P
      Self Employed
      • Oct 2009
      • 1196
      If the UFRII doesn't work you can download the newest PPD v2.90 here. I assume PPD v2.85 for OS 10.2.8 is not working?
      Download the ppd and extract it to /Library/Printers/PPDs/Contents/Resources
      The print engine for a ir2800 is a lot different from the ir2525 so I doubt the same ppd will work, just replace the ppd for the existing printer.
      Open System Preferences->Print & Fax->ir2800->Options & Supplies->Driver.
      Choose Select a driver to use from the Print Using pop-up menu.
      Choose the PPD file you downloaded and extracted (remember the path to it), click OK.
      Make sure the finishing options under the Print Using pop-up menu match your ir2525's
      • teckat
        • 16083
        Canon Phone support is a joke/ UFRII v1.80 Printer Driver for Macintosh OSX should work in MAC 10.4 FOR iR2525I
        OR
        PPD v2.85 for Macintosh OS9.1 or later / OSX 10.2.8 or 10.6.2
        imageRUNNER, Color imageRUNNER and imageRESS PPD v2.85 for Mac OS. (New Support for MacOS X 10.6.2)
